Civil 3D Forum
why do my linetypes look wrong
25 REPLIES 25
Message 1 of 26
cadman33619
6838 Views, 25 Replies
I have a FENCE linetype that isn't quite right. i've attached my drawing and linetype file. The corners don't always meet up and the "X" is sometimes off center...but fine in other parts.
*FENCELINE,X
A,.5,-.2,["X",STANDARD,S=.05,U=0.0,X=-0.13,Y=-0.025],.05
thanks
25 REPLIES 25
Message 21 of 26
Jay_B
in reply to: cadman33619
AutoDesk Subscription customer info, see "learn more" on page.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 22 of 26
Neilw_05
When purchasing the software you have the option to subscribe to free tech support, maintenance and upgrades for 1 year. Whoever was responsible for acquiring your software should be able to tell you if you have a subscription contract and direct you to the person authorized to manage the subscription account. From there you can arrange to access the support service or have someone else with access submit a request in your behalf.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 23 of 26
cadman33619
in reply to: Neilw_05
I will DEF look into it and post any results. in the meantime, I will go back to your post where you suggest removing the U=0 parameter and accept that as my solution.
thanks again
Message 24 of 26
in reply to: Jay_B
I know this is a really old post, but I think it likely has to do with the default height of the text used in the linetype.
Here at my office, our linetypes are defined using the standard font. If, in the text style dialog, we have the standard font default height set to anything but 0, we get unpredictable results with the character height, spacing, etc.
Try setting the default height for the text to 0 and see if the problem persists.
I haven't looked at any attached drawings, so please excuse me if I'm way off.
-Richard
Message 25 of 26
cadman33619
setting the text height to zero is the solution. everything is working great.
thanks for your reply.
Message 26 of 26
chrishowe
I figured one way to fix the text size and it being off centered. very simple it is in the style command for the text. the height of text needs to be 0.000 and that should fix most if not all your problems with your line type not being correct.
Rail Community
