Civil 3D Forum
WHY DO I GET atmp**** AND sav****.tmp FILES WHEN SAVING SOME DWGS
16 REPLIES 16
Message 1 of 17
3250 Views, 16 Replies
WHY DO I GET THESE FILES WITH SOME DWGS AND NOT OTHERS? ANOTHER RESULT IS THAT THE .BAK FILE DOES NOT UPDATE ANY MORE AS THE MOST RECENT BACKUP. I MANUALLY DELETE THE atmp**** & sav****.tmp FILES OTHERWISE THEY KEEP ACCUMULATING.
16 REPLIES 16
Message 2 of 17
jmayo-EE
Did you set the Automatic Save location in the AutoCAD Options dialog to the project folder?
John Mayo
Message 3 of 17
in reply to: jmayo-EE
It is set to the default user\appdata\local\temp location
Message 4 of 17
jmayo-EE
Do you crash when you exit C3D?
John Mayo
Message 5 of 17
Nope, sometimes with this particular dwg I hit save and get a "Drawing is write protected" message and then save again and it works fine.
Message 6 of 17
brian.strandberg
Is this folder a network location?
I rarely have time to post. If what I post helps please use Accept as Solution / Like when appropriate.
Check out my Civil 3d blog at: http://c3dk.com/
Message 7 of 17
in reply to: brian.strandberg
No, this folder is on my hard drive although sometimes I do work throught the network on other dwgs with no problems.
Message 8 of 17
AllenJessup
It sounds like a access/rights problem. If it were on a network the network speed could cause this. For some reason it can't overwrite the bak file. Things to check;
  • Attributes on the BAK file and the Folder rights.
  • If MOVEBAK is set.
  • Is ISAVEBAK set to 1
Allen
Allen Jessup
CAD Manager - Designer
Message 9 of 17
zoeyanne
The files you see are created during the save process.  When you get the error that the drawing is write protected, that means the save process hasn't completed, thus the temp files remain instead of being renamed to the drawing name as they should have been during a successful save process.
Full save:
  1. Full SAVE (which may occur if ISAVEPERCENT>0 )
  2. SAVE the Model.DWG if a full-save occurs and SAVEBAK sysvar is enabled:
  3. Model.BAK deleted
  4. Model.DWG renamed to Model.BAK
  5. Model.DWG in RAM is written out to a .tmp
  6. The .tmp renamed to Model.DWG
  7. Model.DWG remains in RAM for current session.
Model.DWL & Model.DWL2 remain as-is (until user closes Model.DWG, at which time they are deleted.)
Incremental save:
  1. Incremental SAVE (which may occur if ISAVEPERCENT>0 )
  2. SAVE the Model.DWG when SAVEBAK sysvar is enabled:
  3. Model.DWG copied to a .tmp
  4. Model.DWG edits (changes currently in RAM since last save) are written incrementally the .tmp
  5. Model.BAK deleted
  6. Model.DWG renamed to Model.BAK
  7. The .tmp is renamed to Model.DWG
  8. Model.DWG remains in RAM for current session.
Message 10 of 17
wfberry
in reply to: zoeyanne
I think it should be noted that if ISAVEPERCENT = 0 is a FULL SAVE.
Bill
Message 11 of 17
mdhutchinson
You said the files are on the hard drive on your machine?... and this is where these sav and atmp files show up?
Is this correct?
Are you, or your IT department using any software to keep other servers/machine syncronised?
Message 12 of 17
rkmcswain
The .TMP files are almost certainly valid DWG files that could not be renamed to DWG during the otherwise normal SAVE process.
I wouldn't delete them until you're sure you do not need them
Try renaming one to a DWG and see if it opens.
R.K. McSwain     | CADpanacea | on twitter
Message 13 of 17
in reply to: mdhutchinson
Yes the drawing files are on my computer. this doesn't happen with all drawings, so far this is the first.
No we don't use software to keep files synchronized, I do that.
Message 14 of 17
mdhutchinson
We've had this issue now for nearly a year. Two support teams outside our company are working to find the solution.
I could write a book on the subject... but for us it wouldn't have a final ending.
Although I do have a question of late:
Of all the users having this issue... I wonder how many of them use Sheet Set Manager?... and
Could this be a factor?
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Improvi...
Message 15 of 17
rkmcswain
A year? How are you getting anything done? (Not trying to be sarcastic, just curious)
Who are these support teams? Independent? From Autodesk? From your server vendor?
Our similar issue was solved very easily by reverting back to a pure Windows server O/S.  Getting there wasn't easy, but once we did - we've had no issues since.
Message 16 of 17
tcorey
Thank you Zoeyanne. Very well put.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 17 of 17
I do not use sheet set manager.
Rail Community
