WHY DO I GET THESE FILES WITH SOME DWGS AND NOT OTHERS? ANOTHER RESULT IS THAT THE .BAK FILE DOES NOT UPDATE ANY MORE AS THE MOST RECENT BACKUP. I MANUALLY DELETE THE atmp**** & sav****.tmp FILES OTHERWISE THEY KEEP ACCUMULATING.
Nope, sometimes with this particular dwg I hit save and get a "Drawing is write protected" message and then save again and it works fine.
Is this folder a network location?
No, this folder is on my hard drive although sometimes I do work throught the network on other dwgs with no problems.
It sounds like a access/rights problem. If it were on a network the network speed could cause this. For some reason it can't overwrite the bak file. Things to check;
Allen
Allen Jessup
CAD Manager - Designer
The files you see are created during the save process. When you get the error that the drawing is write protected, that means the save process hasn't completed, thus the temp files remain instead of being renamed to the drawing name as they should have been during a successful save process.
Full save:
Model.DWL & Model.DWL2 remain as-is (until user closes Model.DWG, at which time they are deleted.)
Incremental save:
You said the files are on the hard drive on your machine?... and this is where these sav and atmp files show up?
Is this correct?
Are you, or your IT department using any software to keep other servers/machine syncronised?
Yes the drawing files are on my computer. this doesn't happen with all drawings, so far this is the first.
No we don't use software to keep files synchronized, I do that.
We've had this issue now for nearly a year. Two support teams outside our company are working to find the solution.
I could write a book on the subject... but for us it wouldn't have a final ending.
Although I do have a question of late:
Of all the users having this issue... I wonder how many of them use Sheet Set Manager?... and
Could this be a factor?
A year? How are you getting anything done? (Not trying to be sarcastic, just curious)
Who are these support teams? Independent? From Autodesk? From your server vendor?
Our similar issue was solved very easily by reverting back to a pure Windows server O/S. Getting there wasn't easy, but once we did - we've had no issues since.
Thank you Zoeyanne. Very well put.
