Sorry for the vague subject! I am trying to clean up one of my engineers drawings. If you look a the blue dashed lines (number 1 in the attached image), those are my sample line locations. I can turn those off. Look at the lines labeled 2. When I select these, the properties pop up for corridor. I go to the display properties of the corridor, and everything in the display tab is off (see other image attached). I am really needing these magenta lines (number 2) turned off. Any help will be greatly appreciated. MKH
mkh
