Civil 3D Forum
Why can't I turn these lines off?
3 REPLIES 3
MKH-VB
334 Views, 3 Replies
Sorry for the vague subject! I am trying to clean up one of my engineers drawings. If you look a the blue dashed lines (number 1 in the attached image), those are my sample line locations. I can turn those off. Look at the lines labeled 2. When I select these, the properties pop up for corridor. I go to the display properties of the corridor, and everything in the display tab is off (see other image attached). I am really needing these magenta lines (number 2) turned off. Any help will be greatly appreciated. MKH
mkh
3 REPLIES 3
MKH-VB
in reply to: MKH-VB
mkh
Jeff_M
in reply to: MKH-VB
Those are the Links for the assembly. Turn them off via the style used to display them in the CodeSetStyle.
MKH-VB
in reply to: Jeff_M
thanks for that quick reply. Found it!
mkh
Rail Community
