Dear Friends,
I don't undrstand why my assembly line increased after the existing surface in cut and fill condition, it should be stop at the existing surface. due to this problem my cut and fill quantities is not coming accurate. Please anybody can help me to solve this issue? I'm attaching the screens shot of section. I'm using civil 3d 2009 32 bit software.
Thanks.
What Daylight Subassemby is being used?
Daylight MultiIntercept for example has an "Intercept Number" parameter which will allow the Daylight to continue
projecting through the EG multiple times based on this value.
Default is set to 10, Setting this to 1 will force it to tie at the first intersection with the EG Surface.
I've set intercept parameter to 1 but assembly line still increasing in some sections, I don't know what is the actual problem, please I need help.
