Well after further trial and errors I found the solution. So if anyone else was having this problem then here is the solution. The staggering of profiles during Create Sheets is controlled by rows and/or columns using the Multiple Plot option in the Profile View Wizard.
General >Plan Production Tools>Create Sheets>Profile Views
click on Choose settings: Profile View Wizard>Multiple Plot Options
I chose the following options: Rows, 50 profiles, separation distance 200'
I've attached images of the procedure to follow.
Hope this helps someone out.
Bryan Collins
Cadd Technician
Edited by: bryancollins3174 on Apr 6, 2010 5:08 PM
Bryan Collins
Cadd Technician
Windows 7 Prof w/ SP1, 64bit, Xeon 3Ghz, 16GB
Civil 3D 2013
