This is just a query for my own personal interest. Im confused as to why AutoDesk uses the term "daylight" as a term for what i would concider earthworks or interface. The term makes no sense to me what so ever and after a fruitless search the internet for the originals of this term, i have come to the conclusion the term means nothing and AutoDesk just made it up. If im wrong and it is actually an engineering term I would like to be educated
Dan
I would bet that the term comes from the mining and tunneling industry. If you're digging an air shaft or a tunnel to the surface then you cannot specify a distance or elevation on the design drawings. The instruction to the contractor would be:
Excavate in this direction at a specified slope/grade until you reach daylight.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Exactly. Shaft, Tunnel, pitch, whatever to Daylight. May be centuries old.
Allen
Allen Jessup
CAD Manager - Designer
Excellent!
Allen Jessup
I bet it was the Romans...who stole it from the Greeks...who stole it from the Egyptians.
No one "came up with it"
It is simply engineers using the english language as defined
Your Name
