PLEASE, how do I turn this off? i am creating contours in civil 3d, exporttoautocad2010, and there is this white box under the contour label, i don't want this, i DO want it to trim the contour to show the text better but NOT the white box, please advise
it is turned on because if i turn it off it doesnt trim the contour and looks just as bad ... how to have it still trim the contour without the white box?!
You cannot trim a contour, only hide it under another object. You should be able to change the colour of the label mask however to something that's easier to look at.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Mark Green
Working on Civil 3D in Canada
If I remember correctly the background color of the label comes from your current screen background at the time the style was created or changed. I believe that this issue comes from importing a style from a drawing where the background color was different than your current one - don't quote me on this, I might be entirely wrong.
Try changing the modelspace background color then change it back and see if that has any effect.
Steve
