Civil 3D Forum
White Box Under Contour Label!!!!
6 REPLIES 6
872 Views, 6 Replies
PLEASE, how do I turn this off?  i am creating contours in civil 3d, exporttoautocad2010, and there is this white box under the contour label, i don't want this, i DO want it to trim the contour to show the text better but NOT the white box, please advise
6 REPLIES 6
neilyj666
sounds like background mask is turned on for the labels
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
in reply to: neilyj666
it is turned on because if i turn it off it doesnt trim the contour and looks just as bad ... how to have it still trim the contour without the white box?!
sboon
You cannot trim a contour, only hide it under another object.  You should be able to change the colour of the label mask however to something that's easier to look at.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
troma
Select a contour label, and in the properties palette you can switch the "Masking" setting to " Contour line only".
However, it seems to take a while to process. I originally heard of this setting from reading comments from people complaining about how glitchy it is, so be careful!
Mark Green
Working on Civil 3D in Canada
troma
in reply to: sboon
Steve, how do I change the colour of the label mask?
Mark Green
sboon
in reply to: troma
If I remember correctly the background color of the label comes from your current screen background at the time the style was created or changed.  I believe that this issue comes from importing a style from a drawing where the background color was different than your current one - don't quote me on this, I might be entirely wrong.
Try changing the modelspace background color then change it back and see if that has any effect.
Steve
Steve
Rail Community
