Hi all
Every now and then I open a model and the sections/profiles all solid white 'hatch' within the bands.
I have closed down and regenerated in the hope it has something to do with re-freshing the model, but no luck.
Thoughts anyone on how to get rid of this?
Solved by MikeEvansUK. Go to Solution.
You may be in a 3d view. The culprit is the section band style hatching being visible.
Edit the section / profile view bandstyle and turn the hatching off in model and plan views.
Thanks Mike. Since I posted this, I have become far more familiar with the band/profile settings and I should be able ot sort out from here.
