Valued Mentor
kevin.barnett
Message 1 of 7 (1,667 Views)
Which Civil 3D book to purchase (if any)
1667 Views, 6 Replies
01-28-2013 09:12 PM
Greetings,
The information in the Civil 3D Help is usually enough to 'get by' with. But not every option is covered in detail with examples.
Is there maybe a comprehensive book on Civil 3D, published each time a new version is released?
If there is, does it include metric unit tutorials and examples?
Thanks in advance, have a great day,
Kevin.
neilyj
Message 2 of 7 (1,641 Views)
Re: Which Civil 3D book to purchase (if any)
01-29-2013 02:57 AM in reply to: kevin.barnett
The Mastering Civil 3D 20?? series is very good with tutorials etc http://eu.wiley.com/WileyCDA/WileyTitle/productCd-1118281756.html and downloadable tutorial examples in metric and imperial.
I have the 2011 and 2012 editions and they are very useful
Don't forget Youtube as a valuable resource for tips/tricks/methods etc
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Valued Mentor
kevin.barnett
Message 3 of 7 (1,630 Views)
01-29-2013 05:19 AM in reply to: neilyj
neilyj .. thx for replying...
now for the test .. please check your 2012 edition; Does it explain this well:
In Vertical and Horizotal Profile View Band Styles there is a 'Anchor to Label' option, the options are:
Segment in Band and
True Geometry Location
What is the difference? Does the book clearly explain? Do you know the difference?
I need an example to show the difference in these options (Vertical and Horizontal)
Thx,
All the best,
Kevin.
KMercier_C3D
Message 4 of 7 (1,609 Views)
01-29-2013 10:02 AM in reply to: kevin.barnett
Just chiming in to say the Mastering AutoCAD Civil 3D 2013 book does include metric unit tutorials.
Kati Mercier, P.E.
Co-author of "Mastering AutoCAD Civil 3D 2013"
AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
KMercier_C3D
Message 5 of 7 (1,604 Views)
01-29-2013 10:06 AM in reply to: kevin.barnett
Regarding the Vertical and Horizontal Geometry Band Styles, I don't think it is covered in the book actually but per the Civil 3D help:
"Anchor label to
Specifies how labels are anchored in Profile View Horizontal Geometry and Vertical Geometry Bands.
  • Segment in Band anchors the label in the middle of the drawn segment, regardless of whether this is the true middle.
  • True Geometry Location anchors the label to the true middle of the item being labeled. If this location is not shown in the profile view, the label components anchored to that point are not shown either."
Kati Mercier, P.E.
neilyj
Message 6 of 7 (1,588 Views)
01-29-2013 12:21 PM in reply to: kevin.barnett
there you have it - straight from the author....
neilyj
Valued Mentor
kevin.barnett
Message 7 of 7 (1,547 Views)
01-29-2013 09:12 PM in reply to: neilyj
Its good to see that the authors are active here.
Maybe I am guilty of trolling in this instance as I was actually trying to get an example to clarify a setting in Civil 3D.
.. I still need an example showing the difference, maybe it can be included in the 2014 edition? Maybe?
Thx all for your input
If anyone can provide an example showing clearly the difference provided by this setting (Vertical and Horizontal) then please add it to the following post:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Anchor-Label-to-True-Geometry-Location/m-p/3762922
Best wishes to you all,
Kevin.
