Just upgraded from Map 2012 to Civil 2014 but can't find the MapExport command on the Ribbon. The help file says :
"In the Planning And Analysis workspace, click Output tab > Map Data Transfer panel > Map 3D Export"
The panel is there but the Map 3D Export button is not. I can't even find that one command in the CUI editor.
Any ideas?
Solved by Jay_B. Go to Solution.
