I have been looking all around Civil 3D 2013 for the "group" command and cannot find it anywhere! I had it in 2012 and previous versions (and added it to the quick bar).
Any ideas?
Thanks.
C3D doesn't come with the Group command on the ribbon. If you want to add it, you can copy it from the AutoCAD CUI and put it in the Civil 3D CUI.
HERE are the steps (although it's for a different set of tools, the process is the same).
Brian is correcdt. You can also just type G and hit the spacebar or enter.
John Mayo
Also try the CLASSICGROUP command if you like the way is used to work.
