hi everyone,
where is the Bridge Modeler for revit and civil3d ..?
ı look the "labs" links... ı only find empty website page (link deleted or updated)
how ,can we get bridge modeler version 2012 or 2013 ? (when , where....?? )
ı have building design suite 2013 premium but there is no bridge modeler....
they are both subscription extentions
you get from the subscription website
DarrenP
Here's the Autodesk Labs comment on Bridge Modeler:
Bridge Modeler for AutoCAD Civil 3D
Added: November 12, 2009
Graduated: June 29, 2012
The Bridge Modeler for AutoCAD Civil 3D 2012 technology preview focused on 2 purpose-built workflow for modeling bridge road, barriers, piers, abutments, and bearings for bridge types and the ability to extract strings along a bridge and create Civil 3D alignments which can be then used to display key bridge elements onto Civil 3D profiles. The technology preview ceased operation on July 1. Thanks to everyone who provided feedback during the technology preview. This will help shape the technology as it continue to move forward. The technology will soon be available for AutoCAD Civil 3D 2012 in the Subscription Center.
I'm not seeing it in the subscription center yet.
for civil 3d 2013 its this on the subscription center: http://beingcivil.typepad.com/my_weblog/2012/08/subscription-productivity-tools-for-autocad-civil-3d...
for revit its the revit extenstions on the subscription center
DarrenP
I'm not seeing Bridge Modeler on the Productivity Tools for C3D 2013 page. It's not listed in the productivity_tools_for_autocad__civil_3d__20130.pdf document either.
to get the bridge modeler you download the borehole ultity samples.zip and the bridge modeler utility is in that zip file
don't know why
DarrenP
Not any more it isn't - there is no Bridge Modeller for 2013 yet as it is still in beta but contact Dave Simeone at Autodesk if you are interested in testing:
"Now I understand! The problem is being addressed - Thanks for the heads up.
Note to others - please don't try this beta version of the bridge modeler for R2013. If you're interested in evaluating/testing it, please contact me directly.
Thanks!
DAS"
neilyj (No connection with Autodesk other than using the products in the real world)
so i am assuming it was bundled accidently inside that zip file
DarrenP
I think that would be the correct conclusion....
makes sense since autodesk doesn't mention it anywhere even on their own blogs
DarrenP
I am not a fan of broken links. If you navigate to the original link when it was a technology preview on Labs:
http://labs.autodesk.com/utilities/civil3d_bridge/
it takes you to the graduates page. That information was quoted earlier in this thread. In terms of announcing what happened to it, in June when it graduated, it wasn't on Subscription Center yet:
so I couldn't provide the link. I am sorry for the confusion. I have done what I could to cover the bases.
it looks like autodesk posted it back up on the subscription website
DarrenP
Just an FYI for everyone, Bridge Modeler for 2012 & 2013 are now on the Subscription site as of Oct. 19. Note: for 2013 only a 64bit version is available.
This plug-in did not work on my machine. No matter what I do, clean install, update drivers and windows, administrator privilege, disable anti-virus and install at other machine(s), I will always get the AREX error below:
MESSAGE: (29/1/2013 10:49:32 AM)
Show method exception.
Assembly name: DBridgesBeamsGirder: Object reference not set to an instance of an object.; StackTrace: at REX.Bridges.Common.Resources.Dialogs.Common.BTabPanel.InitializeControl()
at REX.Bridges.Common.Resources.Dialogs.Bridge.BElementsControlBase`2.InitializeControl()
at REX.Bridges.Common.Resources.Dialogs.Bridge.BElementsControl`2..ctor(BExtension extension)
at REX.Bridges.Common.Extension.BExtensionControlsBridge.NewDecksControl()
at REX.Bridges.Common.Extension.BExtensionControlsBridge.Initialize()
at REX.Bridges.Common.Extension.BExtension.OnCreateLayout()
at REX.DBridgesBeamsGirder.Extension.OnCreateLayout()
at REX.Common.REXExtension.Setup()
at REX.Common.REXApplication.Show()
DEPENDENCY: Autodesk.REX.Framework, Version=2013.0.0.0, Culture=neutral, PublicKeyToken=51e16e3b26b42eda (file version: 2013.0.0.2251) | REX.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Controls.WPF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Controls.Forms, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Mathematics, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Preferences, Version=2013.0.0.2251, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.System, Version=2013.0.0.2251, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Service, Version=2013.0.0.2251, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251)
LAST ENTRIES: 4 / 36
hi , i want to ask you about that i can't see productivity tools or bridge modeler for civil 3d in on my subscrbtion center , all i have see are about revit , please i need help , thanks in advance .
The bridge modeler is part of the Productivity Tools for Civil 3D.
http://jprdintprev.autodesk.com/sp/servlet/download/item?siteID=11564774&id=20329471
It is available to those who have a Subcription for AutoCAD Civil 3D.
Hi Scott,
I have the subscription and it is not available.
The link you quoted no longer exists.
Where is the Bridge Modeler?
Rad
