AutoCAD Civil 3D General Discussion
*S.T.S.G. Design
Message 1 of 4 (79 Views)
Where do you put in a description key symbol?
79 Views, 3 Replies
11-19-2004 12:23 PM
Where in the description key file do you put the block (symbol) (.dwg) that replaces the point symbol? Like CM.dwg for concrete monument. Why does Autodesk make this so difficult? It was do-able in LDD4. John
*Ron Mills
Message 2 of 4 (79 Views)
Re: Where do you put in a description key symbol?
11-19-2004 01:20 PM in reply to: *S.T.S.G. Design
"S.T.S.G. Design" wrote in message news:419e562f$1_3@newsprd01... > Where in the description key file do you put the block (symbol) (.dwg) > that replaces the point symbol? Like CM.dwg for concrete monument. You don't, you create a point style with that particular block, then reference that point style in your description key manager. > Why does Autodesk make this so difficult? > It was do-able in LDD4. > > > John > >
*S.T.S.G. Design
Message 3 of 4 (79 Views)
11-19-2004 01:23 PM in reply to: *S.T.S.G. Design
thank you, thank you, thank you!!!!! "Ron Mills" wrote in message news:419e63b2$1_1@newsprd01... > "S.T.S.G. Design" wrote in message > news:419e562f$1_3@newsprd01... >> Where in the description key file do you put the block (symbol) (.dwg) >> that replaces the point symbol? Like CM.dwg for concrete monument. > > You don't, you create a point style with that particular block, then > reference that point style in your description key manager. > > >> Why does Autodesk make this so difficult? >> It was do-able in LDD4. >> >> >> John >> >> > >
*Ron Mills
Message 4 of 4 (79 Views)
11-19-2004 01:25 PM in reply to: *S.T.S.G. Design
=) no problem.
Post to the Community
New Post
Need installation help?
