Civil 3D Forum
Where do you put in a description key symbol?
3 REPLIES 3
162 Views, 3 Replies
Where in the description key file do you put the block (symbol) (.dwg) that replaces the point symbol? Like CM.dwg for concrete monument. Why does Autodesk make this so difficult? It was do-able in LDD4. John
3 REPLIES 3
"S.T.S.G. Design" wrote in message news:419e562f$1_3@newsprd01... > Where in the description key file do you put the block (symbol) (.dwg) > that replaces the point symbol? Like CM.dwg for concrete monument. You don't, you create a point style with that particular block, then reference that point style in your description key manager. > Why does Autodesk make this so difficult? > It was do-able in LDD4. > > > John > >
thank you, thank you, thank you!!!!! "Ron Mills" wrote in message news:419e63b2$1_1@newsprd01... > "S.T.S.G. Design" wrote in message > news:419e562f$1_3@newsprd01... >> Where in the description key file do you put the block (symbol) (.dwg) >> that replaces the point symbol? Like CM.dwg for concrete monument. > > You don't, you create a point style with that particular block, then > reference that point style in your description key manager. > > >> Why does Autodesk make this so difficult? >> It was do-able in LDD4. >> >> >> John >> >> > >
😃 no problem.
Rail Community
