Just installed 2012 SP1 and no layers listed. See pic....
Solved by GaryElswick5627. Go to Solution.
Sorry, no answer, just questions 😉
- alfred -
To answer your questions:
1 Yes and no, does not respond to either showing the current layer or if a layer (object) is selected.
2. No, have tried with multiple drawings, same thing, new from template or an existing pre update drawing.
3. See 2.
4. Numerous times over several days.
Thanks for your response!
Tryed Repair, no change, will reinstall over the weekend and post if success.
Please let us know if the complete re-install fixes the issue.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
They are back. Today they work fine. This is several reboots since running repair after which they didn't show.
Note I did not get time to do the reinstall.
So can you confirm if your issue is now resolved or do you still require further assistance.
I look forward to your response.
I am glad to hear it is resolved. Please accept the solution to this forum post.
Thank you.
Rodney, what should Gary select as the solution? None of the posts 'solved' the issue, it seems to have 'fixed itself'. This leads to the questions asked in this thread: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/About-quot-Accept-as-Solution-quot/m-p/3247732
Just curious about your thoughts on this.
Thanks!
This apparently solved the issue:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15851876&linkID=9240697
While resolving a flickering issue I turned on hardware acceleration and it fixed several things including the white viewcube, the layers tab being blank and the flickering screen. However when this happened I was not concentrating on the Layers tab but the other items mentioned so did not notice immediately.
