Civil 3D Forum
Where can I set the styles for aligment labels ?
13 REPLIES 13
Message 1 of 14
tonnot
557 Views, 13 Replies
Maybe I'm a tillte distract but I dont see the way.....
I want to add labels for my aligments. (segments or multiple segments)
I dont see any dialog, c3d directly is asking me to click on aligments
(So I cant choose what styles I want).,
Maybe I have a variable with wrong value ? (Dont show dialog ????)
Thnaks
Civil 3D (2013) how much you have to improve....
13 REPLIES 13
Message 2 of 14
troma
in reply to: tonnot
Click on alignment, right-click, Edit labels.
Then you have a dialoge where you can add many different types of labels.
Mark Green
Working on Civil 3D in Canada
Message 3 of 14
BrianHailey
in reply to: troma
Another way to accomplish the same thing is to select one of the labels on the alignment and then, on the ribbon, choose  "Edit Label Group".
Of course, this assumes you have labels on the alignment already.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 4 of 14
tonnot
in reply to: tonnot
no, no..... I want to use Annotate, add labels, alignment, multipl segments.
I want to add labels for curves and so on.
I cant see the dialog in which I can specfy the labels for curves, etc, I want to use......
I want to specify another style for curves, but I dont know how....
Message 5 of 14
neilyj666
in reply to: tonnot
This dialog box?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 6 of 14
tonnot
in reply to: neilyj666
Yes ,(I supose)  I dont see it.
Message 7 of 14
neilyj666
in reply to: tonnot
It's here on my setup
Message 8 of 14
tonnot
I have this menu !!! But when I clic on multiple segments, I'm asked diretcly at command line to click on an aligment.
Contrary to the other options I have no dialog box prior to setup what I want.....
In addition, I dont see the place to edit the command that drives this.
Thanks again for your help.....
Message 9 of 14
Jay_B
in reply to: tonnot
To preset the styles for the dialog in Neilyj's post go to the Toolspace>Settings Tab>Alignment>Commands>
and select desired styles.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 10 of 14
tonnot
in reply to: Jay_B
Uf, Yes ....
Thanks....
Message 11 of 14
troma
in reply to: tonnot
I took Neil's screenshot.  But click where I circled in red at the top left instead:
This will give you the dialoge box.
Mark Green
Message 12 of 14
tonnot
in reply to: troma
Thanks every body ....
But .... This
Add labels, etc gives me the next :
Command: _AeccAddAlignSegLbls
Adds labels for all segments of polylines, feature lines, lines, and arcs, parcels and alignments.
Labels are placed at mid point of each segment.
Select Alignment: "
And ... I'm unable to set the command to it show me the dialog.
(Maybe I have a bug...).
Thanks Troma and Neil
Message 13 of 14
troma
in reply to: tonnot
Sounds like some setting is messed up. Something along the lines of FILEDIA or ATTDIA, but controls this AddLabels box. Sorry, I don't know what it might be.
Mark Green
Message 14 of 14
tonnot
in reply to: troma
Thanks.... but nothing....
Good weekend !
Rail Community
