Maybe I'm a tillte distract but I dont see the way.....
I want to add labels for my aligments. (segments or multiple segments)
I dont see any dialog, c3d directly is asking me to click on aligments
(So I cant choose what styles I want).,
Maybe I have a variable with wrong value ? (Dont show dialog ????)
Thnaks
Civil 3D (2013) how much you have to improve....
Solved by Jay_B. Go to Solution.
Click on alignment, right-click, Edit labels.
Then you have a dialoge where you can add many different types of labels.
Mark Green
Working on Civil 3D in Canada
Another way to accomplish the same thing is to select one of the labels on the alignment and then, on the ribbon, choose "Edit Label Group".
Of course, this assumes you have labels on the alignment already.
no, no..... I want to use Annotate, add labels, alignment, multipl segments.
I want to add labels for curves and so on.
I cant see the dialog in which I can specfy the labels for curves, etc, I want to use......
I want to specify another style for curves, but I dont know how....
This dialog box?
neilyj (No connection with Autodesk other than using the products in the real world)
Yes ,(I supose) I dont see it.
It's here on my setup
I have this menu !!! But when I clic on multiple segments, I'm asked diretcly at command line to click on an aligment.
Contrary to the other options I have no dialog box prior to setup what I want.....
In addition, I dont see the place to edit the command that drives this.
Thanks again for your help.....
To preset the styles for the dialog in Neilyj's post go to the Toolspace>Settings Tab>Alignment>Commands>
and select desired styles.
Uf, Yes ....
Thanks....
I took Neil's screenshot. But click where I circled in red at the top left instead:
This will give you the dialoge box.
Mark Green
Thanks every body ....
But .... This
Add labels, etc gives me the next :
Command: _AeccAddAlignSegLbls
Adds labels for all segments of polylines, feature lines, lines, and arcs, parcels and alignments.
Labels are placed at mid point of each segment.
Select Alignment: "
And ... I'm unable to set the command to it show me the dialog.
(Maybe I have a bug...).
Thanks Troma and Neil
Mark Green
Thanks.... but nothing....
Good weekend !
