Civil 3D Forum
When the alignment is not at the CL of bridge
9 REPLIES 9
Message 1 of 10
phooi
1123 Views, 9 Replies
I am new in C3D, and my main concern is bridge modeler. I am using C3D 2014.
When I build the corridor, the CL of bridge is always on the top of alignment, but actually my alignment is at 3.65m rightward from CL.
Pls help.
Attached my dwg for your better understanding.
9 REPLIES 9
Message 2 of 10
ericcollins6932
in reply to: phooi
Then build an offset alignment from the CL alignment and have the corridor use that alignment instead as its target.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Message 3 of 10
phooi
in reply to: phooi
Thank you Eric, yes, now my corridor is able to locate at center.
I proceed with my modelling, and now come to another problem :
When I assign superelevation, the rotation axis is at the CL, can I make the rotation axis 3.65 rigthward from CL ? (as shown in attached picture)
Message 4 of 10
ericcollins6932
in reply to: phooi
Not in front of my computer, but if I remember, you typically rotate about either the inside or outside edge as per the super examples. Docs state do not include an offset in an assembly that that will be used with superelevation axis of rotation. The axis of rotation calculation will not run on an assembly that contains an offset.
Win 10
16 GB RAM
Civil 3D 2019
Message 5 of 10
phooi
in reply to: ericcollins6932
Thanks for sharing your knowledge.
So sad that it cannot be done....
Just hope that Autodesk can add this functionality in the future releases.
What I need is to get the coordinates at left edge, right edge and CL of top surface of the bridge at every segment.
Then I try to use Lane assemby for my purpose, and it works.
Another problem occur:
The length of my assembly is 10.04m, but the length measured at the corridor become bigger, i.e. 10.041, 10.043, 10.047, 10.058, etc.
How can this happen ? Does it show the inaccuracy of the software ? or some setting is needed to fine-tune it ?
Message 6 of 10
nikoue
in reply to: phooi
I think that you mesure dimensions using dynamic usc. The horisontal lenght of the your assembly is always 10.04.
Whats you mesure in the drawing is a sloped lenght which depends of the slope of the assembly.
H_Dist=Slope_Dist * Sin(angle)
You mesure the Slope_Dist. The H_Dist is always 10,04.
AutoCAD Civil 3D 2013 Hotfix 3.
Win 8 pro x64, OCZ RevoDrive 240GB
Intel i7 930, 12 GB Ram, Ati Firepro V7800
Message 7 of 10
phooi
in reply to: nikoue
I see, Thank you very much.
How if I want the sloped length always 10.04m, is it possible ?
Message 8 of 10
nikoue
in reply to: phooi
I can’t think an automatic way to do that.
Maybe you can built a custom subassembly in which you can make a parameter of a width witch user must key in e.g 10.04.
After that you can place a second parameter Width Slope with a formula Width_Slope= width/ sin(angle).
The angle is arctan(slope/100). So
Width slope=width/sin(arctan(slope/100)
I don’t know if it can read slope from superelevation.
Of course you can compute manually this width in every section and override it in the section editor.
But really I don’t know why you want that.
Maybe it makes sense in rail design.
Message 9 of 10
fcernst
in reply to: nikoue
You can make an API call for the superelevation in SAC, calculate your required projected subassembly width to effect your desired lane length, and pass that projected width back into the stock subassembly's width parameter.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 10 of 10
phooi
in reply to: fcernst
I think these should be the correct approach.
I still need some time to learn about how to create my own assembly using Subassembly Composer and API function.
Thank you very much !
Rail Community
