Member
kaanturkum
Message 1 of 4 (129 Views)
when opening a drawing contained many gradings, Re-Grade all. So much Time open
129 Views, 3 Replies
09-07-2012 02:18 AM
hi Everyone,
Result = So much Time for openning a drawing
using the datashortcuts : cannot right grading with corridor between other areas.
       if u use the corridor dayligt , area grading and corridor grading is created seperately
      if u use the dinamic feature lines and grading with that way , area grading and corridor grading Right is created RIGHT WAY.
                    But when re-open the drawing, drawing RE-GRADE all finished grading and waiting toooooo much time
THAT S A BIG PROBLEM FOR BIG AREAS OR LONG WAYS
how to solve the RE-GRADING problem on when opening Drawings
BrianHailey
Message 2 of 4 (108 Views)
Re: when opening a drawing contained many gradings, Re-Grade all. So much Time o
09-07-2012 07:51 AM in reply to: kaanturkum
The problem is you are targeting a surface with your grading that is being data referenced into your drawing. When you open the drawing, the surface synchronizes with the original surface. When the surface synchronized it basically rebuilds and the grading recomputes. To get around this, create a new blank surface in your grading drawing and paste in the data referenced surface and do NOT turn on Rebuild Automatic. Now use this new surface as the target for the grading. The primary drawback to this is if the original surface changes, you'll need to manually rebuild the grading target surface.
Brian Hailey
CAD-1.com
My Blog
neilyj
Message 3 of 4 (106 Views)
09-07-2012 07:59 AM in reply to: kaanturkum
This is something that I find quite irritating as well; hopefully this tip will get around it...:smileyhappy:
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Member
kaanturkum
Message 4 of 4 (88 Views)
09-08-2012 01:37 AM in reply to: kaanturkum
thank you very very  much for your help
in my opinion that tip useful for everyone
