I have a set of sheets that have an surface (contours) on them.
When I plot them individually the surface plots fine. When I publish them using the same page setup, the surface will not plot. The contour labels do plot, just not the actual surface contours.
The surface is data shortcuted from another file.
Very strange. Any suggestions?
Philip
Make sure that your shortcut folder is active, then save the dwg with the layoouts you need to publish and try again.
You can not edit after created. That is my problem with catchments.
