0 Kudos
Post 1 of 8
When converting a dwg to a pdf my pdf is huge
219 Views, 7 Replies
06-18-2013 07:44 AM
Does anyone know of a pdf converter that supports 64 bit and helps with the huge pdfs I'm getting.
The dwg does have aerials in them.
thanks
Try the DWG to PDF driver. I used to use CutePDF as well, but the DWG to PDF.pc3 that comes with ACAD works much better. The PDFs will be much more compact and the properties/settings will give you more options. Also, you can use it via the plot command or the publish command.
308 Kudos
Post 2 of 8
Re: When converting a dwg to a pdf my pdf is huge
06-18-2013 08:00 AM in reply to: djocwf54
You can adjust the resolution at which you output the images that become part of the pdf.
PageSetupManager, Modify.
Properties (next to the output device name), then Custom Properties. You'll see the option for raster resolution in there.
Cutting the output resolution in half reduces the file size (or at least the part taken up by the images) by four times.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
0 Kudos
Post 3 of 8
06-18-2013 09:46 AM in reply to: djocwf54
I see raster resolution under graphics so i lowered that but it didnt let me open it after i saved it
Valued Mentor
62 Kudos
Post 4 of 8
06-18-2013 09:50 AM in reply to: djocwf54
Are you using the DWG to PDF driver that came with AutoCAD?
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
329 Kudos
Post 5 of 8
06-18-2013 10:39 AM in reply to: djocwf54
I concur with Tim. these setting give us acceptable prints and has lowered 10mb files to 5mb. if you are looking to go lower you'll probably have to scan a hard copy
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
0 Kudos
Post 6 of 8
06-18-2013 11:01 AM in reply to: djocwf54
No i was using a cutepdf software
it didnt work. i couldnt open it after exporting it
Valued Mentor
62 Kudos
Post 7 of 8
06-18-2013 11:06 AM in reply to: djocwf54
-Ian McClain
0 Kudos
Post 8 of 8
06-18-2013 09:36 PM in reply to: djocwf54
Use plot command and select the DWG TO PDF.PC3 in printers option, it's allready comes with autocad software.
This is the best way.
I.V.S GOPAL
CAD Engineer
