IF({Inner Structure Width}=4 &{Inner Structure Length}=4,{Rim to Sump Height},-1)
My structure table is list -1 for all
Joe Bouza
Solved by Joe-Bouza. Go to Solution.
Solved by doni49. Go to Solution.
Joe Bouza
Joe Bouza
The part builder say 48x48 the structure props say 4x4. My work around was to give the frame width a unique size and it like that expression using feet.
Joe Bouza
OK, now that I have access to C3D I can see that the length/width can be input in feet. But something is strange...I just tested your original expression modified to return either 1 or 0 and used this as a label's X offset value as well as the label contents. The label updated & moved, as expected, when I edited the structure width or length. I then changed the 1 to be the {Rim to Sump height} and the label changed as if the check failed just as you were seeing. This is where it gets real weird, I can no longer get the expression to work at all, even by replacing the {Rim to Sump height} with a 1 again.
Wow.
Thanks for looking into this, Jeff. I don't know if you saw my previous post for the work around; reading frame width seems to work.
Now my issue is rounding. I want to roundup(RimToSumpHeight) and its not reacting. First, help doesn't show an additional argument and the composer asks for one. Thinking Excel I used roundup(RimToSumpHeight,-1). the composer likes it but the style does not; nothing rounds. I was hoping to add contingency with an expression too, but its looking grim 🙂
Joe Bouza
@Joe-Bouza wrote:
Wow.
Joe,
What's the purpose of the NEGATIVE 1? What place do you want to round to?
Don Ireland
Engineering Design Technician
Using excel as an example:
The "Rounded Value" column shows how the original number "A1" gets rounded using ROUNDUP and the number from the second column for that second argument.
Don Ireland
Joe Bouza
Joe Bouza
