This is probably a stupid question, but I can't find an answer anywhere on the Internet. What type of objects can be projected into a profile view? I know that points, feature lines, and multiview blocks can be projected with variable results. I can't even find a simple list within Civil 3D's useless help.
Fred
-Civil 3D 2012
I only have 2013 installed so this is from that installs help.
"You can project AutoCAD points, blocks, 3D solids, and 3D polylines; you can also project AutoCAD Civil 3D COGO points, feature lines, and survey figures. "
That explains why I can't project an alignment. Darn.
Alignment?
What are you looking to do?
Your Name
Your Name
I was trying to find a list that lets me know what objects can be projected onto profile or section view.
You can create a featureline from an alignment and project that onto a profile. You can also project profiles from an another alignment onto a profile.
Everyone is trying to make this way too complicated. All I wanted was a simple list like below.
Autocad Points
Autocad Blocks
Autocad 3D Solids
Autocad 3D Polylines
Civil 3D Points
Civil 3D Feature Lines
Civil 3D Survey Figures
Civil 3D Profiles
I don't think that was Neils's or anyones intent, but when you say you want to project an alignment - one has to ask ?
The list you have thus far seems like a good start. Imperical data will be your greatest resourse to hopefully expand upon that list
Your Name
Your Name
Everyone is not trying to be complicated. Everyone is trying to help. Very often we come here with one idea of what we want to do, but it is not possible. Others then help us to find a different way of getting to our goal.
Mark Green
Working on Civil 3D in Canada
I tried projecting a line, a polyline, an alignment, a circle, a feature line, and a point, and I had success only with the feature line and the point. I found nothing, nada, zip when I was looking for a list of the items that can be projected into a profile.
I had some free time and I was playing with different styles and tools to try to figure out how to do things differently. Hopefully to figure an easier way for others to accomplish certain tasks. Curiosity nipped this cat, and I was wondering if anyone else had any success to projecting certain items without having to use a work around.
I've never had a problem projecting objects to a view: Blocks, points, FL.
I've not run into a need to project something that told me no way.
I still would like to understand what you would do with a projected alignemnt to a profile (sounds funny because a profile is a projected alignment)
Your Name
Your Name
-Civil 3D 2012
From C3D2012's 'useless' help under Profiles:
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-3E3DB171-1B07-41A8-88EA-BA41204C2C0-1536.htm
Looks like it includes a list of objects that can be projected.
Thank you for finding that for me. That was what I was looking for. I could go on a rant prior to 2012 I found the solution to 80% of my problems under help, and after 2012, I can't find anything.
This is from Berry's FAKS sheet. The place to look for answers involving Civil 3D is Google. Quite amazing.
Bill
