I'm not finding Help very helpful in 2015 - is there a support path needed or something?
neilyj (No connection with Autodesk other than using the products in the real world)
Neil,
I've never had much luck getting Help through the program. Try Google instead:
http://help.autodesk.com/view/CIV3D/2015/ENU/?guid=GUID-B6CF98F9-FF6F-4FF5-8022-60EB21A611A7
Dave
Dave Stoll
Las Vegas, Nevada
The help from my civil 3d 2015 seems to be working as designed.
When I search on msltscale in civil 3ds help, I get the same result as shown in Dave's post.
Tried PEDIT in the civil help and got the Left hand of the image and tried the Online version and got the information as expected
+1
Don Ireland
Engineering Design Technician
...and this is my OOTB help file path
Does that path exist? It doesn't look right compared to any of the installs I've done of C3D/IDS 2015.
Seems to.....I'm using the British English version which may be the reason?
@neilyj666 wrote:Seems to.....I'm using the British English version which may be the reason?
That's your problem. You should stop using the Queen's English and start using the true English from 'Merica! 🙂
As to the problem, I've seen many issues with the 2015 installs using wrong support paths. It could be the UK version has the wrong path for the help files. Have you tried actually finding the files and adding that path?
