Labels: Moving from location as saved in '07 upon opening in '08. Extra Grips that do nothing associated with labels.
Section Views:
Setting you section view padding to 0 in the horizontal results in the labels being labeled from outside in rather then inside out at your specified Major and Minor tick Intervals. Setting the Cell Padding to 1.0 on the both the left & right causes the issue to go away but for me results in a 2" wider section which no longer fits the vertical text in to the viewport in my layout.
i.e.
2007: 40' Major, 10' Minor Horz.; 4' Major 1' Minor Vert. resulted in
24 24
20 20
16 16
12 12
-120 -80 -40 0 40 80 120
2008:
24 24
20 20
16 16
12 12
-102 -62 -22 18 58 98 138
Profiles:
Pipes are upside down depending on whether drawn from left to right or right to left in the plan. Label styles using Pipe Bottom or Pipe Top anchor points are affected.
Profile Labels no longer seem to have the "Flip Label" function attached to them. (specifically grade breaks) I have some tall profiles where it was necessary to flip the labels from above to below the profile to fix the view in my layout viewport. After opening this 07 file in 08 I can no longer flip the labels and they have revered to there original above the line position.
I'm sure I'll be back to post more f-up's in '08. But I have a job needs to be out Monday morning and I don't have time to FIX, Work-Around, Repair, Recover or Recreate this project in '08.
I'll just have to suffer '07's instability and truly miserly performance as well as dump my last 6 hours of work in '08 as the files are no longer usable in '07.
For me C3D =
Productivity down,
Job Quality down,
Customer satisfaction down,
Weekends available for recreation vs. Overtime down,
Job satisfaction down,
