Civil 3D Forum
what might be the problem of my profile
4 REPLIES 4
bigexploit
188 Views, 4 Replies
i create a profile from a surface, it refuse to draw in horizontally(along stations) instead vertically
4 REPLIES 4
Jeff_M
in reply to: bigexploit
For one, there are a number of Points with an elevation of 0. Set your EG point group to exclude points with elevations <1000 and it gets better.
Next, that is extremely steep terrain....slopes of 20%-900%, is this correct?
Jeff_M, also a frequent Swamper
Jay_B
Jeff's quicker than I Smiley Happy but since I took a look I will also share what I found.
The Minimum & Maximum surface elevations can be viewed in Surface Properties and you've included zero elevation points in the surface definition as Jeff points out.
And when your EG Point Group is sorted by elevation, the zero elvations are easily found in the points listing.
Hope that Helps.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
bigexploit
in reply to: Jeff_M
absolutly but does the deeply terrian has anything to do with that. please what other solution
Jeff_M
It drops 200+ meters in 8 meters in one spot check. So if this is really what it does, then the profile is correct (after excluding the 0 elevation points).
Rail Community
