i create a profile from a surface, it refuse to draw in horizontally(along stations) instead vertically
Jeff's quicker than I but since I took a look I will also share what I found.
The Minimum & Maximum surface elevations can be viewed in Surface Properties and you've included zero elevation points in the surface definition as Jeff points out.
And when your EG Point Group is sorted by elevation, the zero elvations are easily found in the points listing.
Hope that Helps.
