Hello all,
(sorry, i posted this in wishes by accident first)
This symbol just started showing up on any drawing I open in Civil 3d 2012. It also shows up on "Drawing 1" when I start cad. It doesn't have any sort of message when I hover over it, I can't click on it, and everything seems to be working,,,
I started work this morning in a drawing and it wasn't there, closed cad, started cad, and it was there.
Has anyone seen this before?
Sorry if this has been covered; I tried looking for it the boards, but it's hard to describe in the search.
Rand Waltz
Solved by neilyj666. Go to Solution.
It's Level of Detail - found under the View Tab in the ribbon see http://beingcivil.typepad.com/my_weblog/2011/05/autocad-civil-3d-2012-preview-surface-level-of-detai...
neilyj (No connection with Autodesk other than using the products in the real world)
You just got to it first Jeff....
Wow! Sudden Service!
Thanks to both of you. I had opened a drawing with a lidar-based surface earlier and that dialog box popped up. Earlier I had ignored it but last time I said okay.
Thanks again!
Rand Waltz
