Active Contributor
rand
Message 1 of 5 (249 Views)
What is this?... Again
249 Views, 4 Replies
10-01-2012 11:18 AM
Hello all,
(sorry, i posted this in wishes by accident first)
This symbol just started showing up on any drawing I open in Civil 3d 2012.  It also shows up on "Drawing 1" when I start cad. It doesn't have any sort of message when I hover over it, I can't click on it, and everything seems to be working,,,
I started work this morning in a drawing and it wasn't there, closed cad, started cad, and it was there.
Has anyone seen this before?
Sorry if this has been covered; I tried looking for it the boards, but it's hard to describe in the search.
Rand Waltz
Jeff_M
Message 2 of 5 (243 Views)
Re: What is this?... Again
10-01-2012 11:20 AM in reply to: rand
It indicates that Level of Detail is turned on.
neilyj
Message 3 of 5 (240 Views)
10-01-2012 11:21 AM in reply to: rand
It's Level of Detail - found under the View Tab in the ribbon see http://beingcivil.typepad.com/my_weblog/2011/05/autocad-civil-3d-2012-preview-surface-level-of-detai...
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
neilyj
Message 4 of 5 (236 Views)
10-01-2012 11:22 AM in reply to: neilyj
You just got to it first Jeff....:smileyhappy:
neilyj
Active Contributor
rand
Message 5 of 5 (233 Views)
10-01-2012 11:25 AM in reply to: neilyj
Wow! Sudden Service!
Thanks to both of you.  I had opened a drawing with a lidar-based surface earlier and that dialog box popped up.  Earlier I had ignored it but last time I said okay.
Thanks again!
Rand Waltz
