Civil 3D Forum
What is an ADTS Audio file?
7 REPLIES 7
Message 1 of 8
10443 Views, 7 Replies
civil3d is creating audio files upon fatal error. Does anyone know what these are?
7 REPLIES 7
Message 2 of 8
AlmasSuljevic
Hi Joe,
The ADT files are files that get created when you run AUDIT command. The reason they show up as audio files may be that the default for ADT was set to be one of the programs such as Windows Media Player or Real Player. If you open it with Notepad you will see its content. You may want to change the defaults, too.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Tags (1)
Message 3 of 8
in reply to: AlmasSuljevic
Hi Almas, do I want to keep those files?
Message 4 of 8
AlmasSuljevic
Hi Joe,
You don't have to. They are good for troubleshooting only in case you want to send them for investigation.
Almas Suljevic
Message 5 of 8
Good to know. Smiley Very Happy
Message 6 of 8
neilyj666
For all the good submitting files to Autodesk does, you'd be better off trying to listen to the files...!!!!!!!!
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 8
AlmasSuljevic
in reply to: neilyj666
That'd be fun file to listen. Smiley Very Happy
Almas Suljevic
Message 8 of 8
Hello,  I am getting these files in my folders and I haven't run an audit.  Is doing a recover the same thing?
Or are they just created automatically if your computer crashes??
I have been having trouble with files, all my layers are being discarded and turned into an AUDIT_BAD_LAYER and then the file is virtually useless.
Why is this happening?
Any help would be greatly appreciated.
Carole
Rail Community
