Solved by AlmasSuljevic. Go to Solution.
Via Google: http://filext.com/file-extension/GRS shows:
Detailed information for file extension GRS:
Identifying characters Hex: 50 4B 03 04 14 00 , ASCII: PK
Other applications associated with file type GRS:
Sometimes it helps to open the file with text editor and read the first few lines to get an idea what the file is about
I am getting the message:
The external file
F:\DWG\Quarterly\Q2-2012_1946f7.grs
associated with the surface Grid from DEM file Overall_GM could not be found
I have a DEM with that name, but not in this drawing and I haven't been able to reference it in my system.
When you save a drawing containing a large surface, the data pertaining to the large surface is written to a separate file that is saved in the same location where the surface drawing resides. The TIN surface companion files have the .mms file extension, and the grid surface files have the .grs file extension. I believe this is where your GRS file is coming from.
Just make sure this file is placed next to the drawing file and you may be all set.
Thank you for responding.
I have searched the directory for such a file and have found none.
All of the files that I am opening that inform of the missing .grs do not reference the DEM (grid), or any surface for that matter.
Is this something within the shared Civil 3D projects? I have searched all of the Project xml files that are sharing project surfaces and have not found a reference to the DEM or the grs. Not too sure where this is coming from...
we just started to have the same problem with civil 3d here in our office. It doesn't happen with every project just one or two so far. I haven't really been able to find any solutions but I think exporting out as an xml and then reimporting the surface and then exporting the drawing to acad might work.
Dylan
