Hi guys,
Im trying to find out what a corridor link is, im trying to run a 'Corridor Setting Out Report - Slope and Offset' Report and its asking for a corridor link, ive search the help section and ive looked on google and i cant for the life of me work out what it is.
Ive attached a file showing the location of the corridor link on the report menu.
Regards
Dan
I ran a slope stake report on a drawing with an existing corridor, and the drop-down box for 'Select Corridor Link' populates with the link names as defined in the assembly & subassembly link codes (see image below).
Are you using an assembly (or assemblies) that do not have Link Codes assigned to the links?
The link codes in the corridor come from the link codes in the subassembly. Most of the subassemblies are pre-coded in Civil 3D with the exception of some of the "generic or basic" subassemblies. The other time you might see this is if the subassembly was created in subassembly composer and there wasn't a link code defined.
Links span and connect subassembly points orthogonal to the Baseline.
I encountered the same issue. I created new sample lines and processed the slope stake report using the new sample lines and issue was resolved. I hope it work for you too.
