Civil 3D Forum
WEIRD ZOOM ISSUE WHEN ENTERING MODEL SPACE
6 REPLIES 6
idigg-be
1098 Views, 6 Replies
whenever i enter model space, or open a drawing the drawing zooms to some odd isometric view.  zoom previous fixes this, but it has become annoying quickly.  i read this was a bug fix in SP1, but i JUST installed civil3d2013 2 days ago.  it doesnt seem to happen in all my drawings.
6 REPLIES 6
idigg-be
in reply to: idigg-be
I also noticed that when switching to model space ucsfollow keeps returning to 1.  i want it set to 0 so i can enter viewports with out it zooming extents constantly.
BrianHailey
Just to verify, did you install the service pack when you installed C3D? The install files aren't updated with the service packs, they still need to be added. You can install the service packs as you install the program however.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
idigg-be
in reply to: BrianHailey
Thanks for the response.  yeah, i ended up installing the SP and it fixed that problem.
JC000
Hi
I have a quite similar problem.
Whenever I enter model space, or open a drawing, it zooms to some view where I can't see anything.  Zoom previous fixes this too. It doesn't happen in all my drawings either.
Otherwise if I do several undos then I get the previous view but it closes some XREFs !
I use a french version of Map 2013, with an add-on called COVADIS.
Service pack 1 has been installed.
Any suggestion welcome.
Autocad Map 3D 2013 - COVADIS 13g (french)
troma
in reply to: JC000
UCSFOLLOW     ?
Mark Green
Working on Civil 3D in Canada
JC000
in reply to: troma
Thanks for that.
UCSFOLLOW is set at 0, never changes (that I can see).
Rail Community
