Kurt,
We screen back our pipes with ctb files for each type of sheet(ie. water, storm). Won't fix the centerline problem but it may help your productivity so you don't have to switch colors every new sheet that you create.
Ryan
Running in to the same problem here. My workaround is much simpler and easy. I just put the current layer to the "0" layer and it shows up as it should. I hope this helps somone.
@Anonymous wrote:Running in to the same problem here. My workaround is much simpler and easy. I just put the current layer to the "0" layer and it shows up as it should. I hope this helps somone.
This is what I've gotten in the habit of doing as well... right before I plot. Sometime I forget though.
This is very frustrating. I'm not sure why there hasn't been a real fix for this from AutoDesk yet. I just hope it doesn't show up in the 2012 version of Civil 3D.
Kurt
@Anonymous wrote:Kurt,
Ryan
I actually have all my sheet layouts setup with layer/color information (by viewport) appropriate for each plan and included in my template drawing, so I don't have to switch colors. Until this glitch is corrected, I just have to remember to set my current layer to "0" and hit regen prior to plotting.
Kurt
I haven't had a chance to download 2012 yet, has this been fixed in 2012. Is autodesk planning on fixing this in 2011?
Cory
Kurt,
Read the rest of the comments on this page. I have found that you need to use a hatch pattern instead of displaying the centerline for the pipe. The centerline acts as a block with linework on the 0 layer. The hatch pattern is somewhere on this forum. I can't remember where they are located on my machine but if you know or someone can tell me where the PAT file are kept I can find it for you.
Ryan
I'm not sure that is the case with the pipe centerlines but the problem I was having with the structures showing up on the current layer was caused by the style having somehow lost its layer setting. When I reset the layer it fixes the problem. Not sure what caused it to lose the layer setting but I am currently unable to duplicate this issue with my current template.
Cory
