I'm getting this message when atttempting to save - anyone got any further info on it?
neilyj (No connection with Autodesk other than using the products in the real world)
Hi Neil,
We work largely on a network, and have occasionally had the network drives fill up, and that is the message we get when trying to save to a location where there is not enough space for the drawing file. The only way I found to resolve this was either have to free up space on the network drive or save to a different location. You mentioned that you have been having connectivity issues, so it may be related to that as well.
Hope that helps,
Norm
Looks like a server glitch - I get that about 3-4 times a month, or the drive is full, or your C drive. My got loaded up last friday and that happened
Your Name
Neil
We get this from time to time. Wouldn't have a clue why it occurs, but if I do an audit, I am then immediately able to save no worries. In the audit, it doesn't even seem to matter whether you fix the errors or not, just as long as you run the audit it seems to save.
Cheers
