the boss has some weird graphics issues in c3d2015. stray lines appear but can'r be picked and the change when he zooms in or out. crazy. see attached image.
Solved by Citadel2012. Go to Solution.
Looks like some sort of annotative issue. Check any annotative objects (dimensions, multileaders, etc.)
maybe but i doubt it. they aren't even objects, just stuff showing up on screen.
Have you tried running an audit? Also, is your hardware acceleration turned on?
turned off HA. thanks.
@nostupidquestions wrote:the boss has some weird graphics issues in c3d2015. stray lines appear but can'r be picked and the change when he zooms in or out. crazy. see attached image.
It's actually a known bug that supposedly SP1 for AutoCAD fixes.
