Civil 3D Forum
Weird Issue Xref binding itslef to other obhects.
5 REPLIES 5
Chaznsc
231 Views, 5 Replies
I have a very strange issue with an XREF. Its a CAD GIS file I am using for some basin study work. Somehow, it has bound itself to my main drawings utility (water) lines. If I go into the XREF root file, the water main is not present (and it shouldnt be) but it has somehow bound itself to that layer. I have tried changing the layer the XREF resides on with no success. Audit did nothing, and I am perplexed!
Any ideas welcome.
5 REPLIES 5
troma
in reply to: Chaznsc
@chaz wrote:
I have a very strange issue with an XREF. Its a CAD GIS file I am using for some basin study work. Somehow, it has bound itself to my main drawings utility (water) lines. [What does that mean?] If I go into the XREF root file, the water main is not present (and it shouldnt be) [so this is good then] but it has somehow bound itself to that layer. [What does that mean?] I have tried changing the layer the XREF resides on with no success. Audit did nothing, and I am perplexed!
Any ideas welcome.
Having trouble understanding what's going on for you.
Mark Green
Working on Civil 3D in Canada
Chaznsc
in reply to: troma
OK, here is whats happening
Have a base map with
TOPO
UTILITY MAINS
PAVEMENT
Have an XREF created after the base map that contains:
GIS TOPO
GIS ROADS
Now the UTILITY MAIN LAYER is "bound" the XREF when the XREF layer is thawed. So if I select the UTILITY MAIN linework, it selects the XREF file. When I freeze the XREF layer, bye bye UTILITY MAIN later. Delete the XREF and it take the UTILITY MAIN with it.
wfberry
Your XREF is attached to your Utility layer.  Change it to perhaps the "0" layer.
Bill
Chaznsc
in reply to: wfberry
I checked that, it's on it's own layer independent from the utility layer. Regardless it shouldn't capture the line work. For instance, if I select a line on the utility layer, the serf gets picked as well.
gccdaemon
Sounds like a circular reference to me. Might want ot check x-refs and make sure they're set to overlay.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Rail Community
