Civillers,
I have a question weeding lines
First let me explain whats going on.
I have
I have a pointcloud data
i have one line.
i need
ASCII with p/x/y/z/ a code/stationing.
heigts on line with these specs:
Heigtdifference between 2 points smaller then 30 cm
max distance between 2 points 50 meters
min distance between 2 points 1 meter.
When i drop the line on a surface is has alot of vertices. and i want too weed it whit minimun demands from client.
do you have any suggestion? I would very glad iff someone know a automatic solution.
Thanks in advance.
Greets G.
You probably had "Insert intermediate grade break points" selected.
Recreate the Featureline without the intermediate points and add Elevation points using the increment option.
Allen
Allen Jessup
CAD Manager - Designer
