I've made a surface using Lidar data that was sent to me, but the LiDAR picked up trees and various other different things we dont need in the surface. Is there a way to quickly remove these points. I cant weed by level becuase the site is uneven so that would mean losing some of the site.
Solved by ksorsby. Go to Solution.
You have DSM data, you need DTM data (which is DSM data but with automated filtering to remove vegetation etc.). Your options are to obtain or purchase the DTM data (it's not expensive) or manually edit the points and features out.
If purchasing is not possible, you'll need to use a surface style which shows surface points and contours, then delete the points you don't want or until the contours look right. You can delete using window or CP I think. A better option IMO is to 'patch edit', ie. draw around the offending areas, drape the polyline to pick up the surface levels, create a surface called, say, Patch1 and then paste that into your main surface. Effectively flattening the areas of trees etc.
Allow plenty of time though!
Kevin
Globel Mapper is good for this. You can set different classifications to remove vegetation.
