Dear all.
please help. i have this lisp to draw a profile as the data entry in the excel sheet. what i want is to add some modifications on the lisp as to:
it would be tooo much helpful for many and thank you very much all for help.
You're asking a lot. You're not likely to find someone who will do all this for free. If you're willing to pay for programming services, I suggest you post in the Autodesk Classifieds group.
Hi Hasan,
My answer for sure will not be solution for your situation. But your question made me interested if I can solve this with our software Urbano. I am coming from the company Studio ARS which is producer of the software Urbano for pipe infrastructure. More information about software you can find on our web address - www.studioars.com
I did the next things:
1. Take your original XLS file and make some modifications:
a) add node names according to your pipeline names (A1, A2, ..., B1, B2, ...)
b) from your stations I create x and y coordinates. For every pipeline I take x as constant and y receive value of stations. With that I can generate layout which is not realistic but I need it in following procedure
2. Copy the changed XLS to text file with (PT extension)
3. Read the PT file and draw the layout with elevation data
4. Draw profiles
5. Read the diameters from the PT file as scalar values
6. Bind the values with real pipes from the catalog
Later on, I found that made mistake because I read grade line as terrain and level line. It is possible to read all lines - terrain, level line and grade line as additional terrain. But now I do not have time to correct the mistake.
I attach the link with the video in which you can see the procedure.
https://www.youtube.com/watch?v=Fs_IOH55HQE
Best regards,
Drazen Galic
d dot galic at studioars dot hr
just load the lisp. type command <ap> then load the file 123 then type command <sf> v: 1:100 and h: 1:1000 or 1:2000 whatever u want.
