Civil 3D Forum
Warning message
5 REPLIES 5
losfotos
472 Views, 5 Replies
Warning message
Anyone ever seen this message when saving? This is a new one on me.
*Warning* Multiply owned object, handle "99E6"
Carl Simpson
C3D 2015 & 2016
5 REPLIES 5
Jeff_M
in reply to: losfotos
Yep, it's been seen a little bit Smiley Happy
Most often happens when copying child styles from one drawing to another, but could have several other possible causes.
(entget (handent "141B")) will tell you what that object is.
(entdel (handent "141B")) will delete it
Jeff_M, also a frequent Swamper
losfotos
in reply to: Jeff_M
Thanks Jeff
Carl Simpson
C3D 2015 & 2016
losfotos
in reply to: Jeff_M
So I did this and all seemed great. Until I came in this morning and every single feature line I had in that drawing vanished... Whatever entity it is that this deletes it removes all the feature lines from the drawing.
Carl Simpson
C3D 2015 & 2016
Jeff_M
Did you use the first line of code to see what that entity was? Do you have the .bak file from before you did this? If so, rename the current dwg (exit without saving) to .dwg-old, then rename the .bak file to .dwg.
I've never had an issue just removing those objects, however it sounds like yours was tied to the styles, or Site. Are the f/l's still showing in the Site under Prospector?
losfotos
in reply to: Jeff_M
I did and it didn't show me anything... It just ran it and went back to the command line. I'm in the process of trying to redo the drawing because I can't audit/purge and then save. It gives me a fatal error. Super frustrating.
Carl Simpson
C3D 2015 & 2016
Rail Community
