Valued Contributor
losfotos
Message 1 of 6 (170 Views)
Warning message
170 Views, 5 Replies
03-04-2014 04:13 PM
Anyone ever seen this message when saving? This is a new one on me.
*Warning* Multiply owned object, handle "99E6"
Carl Simpson
C3D 2013, SP 2
Yep, it's been seen a little bit :smileyhappy:
Most often happens when copying child styles from one drawing to another, but could have several other possible causes.
(entget (handent "141B")) will tell you what that object is.
(entdel (handent "141B")) will delete it
Jeff_M
Message 2 of 6 (158 Views)
Re: Warning message
03-04-2014 04:25 PM in reply to: losfotos
Valued Contributor
losfotos
Message 3 of 6 (153 Views)
Re: Warning message
03-04-2014 04:42 PM in reply to: Jeff_M
Thanks Jeff
Carl Simpson
C3D 2013, SP 2
Valued Contributor
losfotos
Message 4 of 6 (98 Views)
Re: Warning message
03-05-2014 08:56 AM in reply to: Jeff_M
So I did this and all seemed great. Until I came in this morning and every single feature line I had in that drawing vanished... Whatever entity it is that this deletes it removes all the feature lines from the drawing.
Carl Simpson
C3D 2013, SP 2
Jeff_M
Message 5 of 6 (91 Views)
Re: Warning message
03-05-2014 09:16 AM in reply to: losfotos
Did you use the first line of code to see what that entity was? Do you have the .bak file from before you did this? If so, rename the current dwg (exit without saving) to .dwg-old, then rename the .bak file to .dwg.
I've never had an issue just removing those objects, however it sounds like yours was tied to the styles, or Site. Are the f/l's still showing in the Site under Prospector?
Valued Contributor
losfotos
Message 6 of 6 (85 Views)
Re: Warning message
03-05-2014 09:59 AM in reply to: Jeff_M
I did and it didn't show me anything... It just ran it and went back to the command line. I'm in the process of trying to redo the drawing because I can't audit/purge and then save. It gives me a fatal error. Super frustrating.
Carl Simpson
C3D 2013, SP 2
