I am having a problem with my Surface not cutting to the exact Wall Breaklines that I have drawn..The problem areas are the vertical wall to the north in the drawing. Specifically the vertical 90 corners. I have attached my file. Thank you.
Solved by AllenJessup. Go to Solution.
Are they supposed to be squared like this?
Allen Jessup
CAD Manager - Designer
Yes, exactley except hard to tell if the top of the wall is sloping in elevation but yes that's how i wish it to look like..
Joe Bouza
I could be. I will recut the surface using no upper lines, like I have done for the walls running North/South and retry..
I have tried removing the upper lines and it worked almost brilliantly see attached. I have only one small area to fix. See attached.
OK. Despite what I said before. I had to look at it more closely. actualy looking at it from the underside let me see what was happening better.
I moved the bottom of wall away by 0.01 and flattend the peaked breakline i showed in the other screenshot by picking the Mid between 2 Points using the adjacen verticies. One difference between the one that worked for you is that it was create with a flat polyline. The others were created as segments of 3D polylines.
Allen
Allen Jessup
That's how I thought it was suppose to be Allen. Note that there are a number of surf warnings and errors. Mapclean does find some duplicate objects which also does not fly well with the algorithms.
There is also points and a line defined as a drawing objects This also adds to the errors. If the line lies on all of the points remove the line. This is data redundancy.
John Mayo
For some reason, I clicked on the surface and swaped the line that was crazy and it seems to have worked. I didn't notice the difference in Polylines. Thank you very much for your help, Allen. 🙂
