Just to point out my own guffaw... the correct, easy and OBVIOUS way to do simple grading to a surface is with the generic link LinkSlopeToSurface! Don't I feel silly. I knew there had to be a better way that to trick the basic ditch sub to 0 bottom and sides, I just kept using the tool I created from this workaround on the first day I ever created an assembly. Guess I'm just a creature of habit. It was Peter Funk's webcast of Sept. 16, 2005 (yes, 2005) that finally idiot-proofed it for me. Sorry for the stupid question earlier. It's so simple and obvious I'll bet no one ever knew what I was babbeling on about (as usual?).
Brent, did you ever get your task completed? I finally got the "smart wall" I thought you were asking for to work and Peter of Cadtown was right, it was quite simple once you draw the links in order (duh again). Well, I suppose most mistakes are stupid ones when looking at them in the rearview mirror... Like so many things in life, I had to learn the hard way (but I'm not bitter against the ex... or maybe I am). At least I shouldn't do it again!
Shout out if you need to,
John
