Hello. I have cross-sectiosn and volum tables on each cross-section, in volum tables i have cut area but i do not need it and i can not DELETE it, is it possible to delete CUT AREA?
Yes you can remove the cut area field from the Volume table. Under Section view properties, Volume Tables Tab, Edit the table style. The fileds you include in the table can be chosen just like the data they potray. The headings too can be edited.
The dialog for the various table styles won't let you delete the first column. What you should be able to do instead is copy everything over from the second column then delete that one.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
