Civil 3D Forum
Volume Table display in Viewport is Staked
4 REPLIES 4
Terrain_IaPLS
523 Views, 4 Replies
Quick ? about a Volume Table style, where I have correctly showing in Model Space
and is "Split" in the Table Properties.  This is a "Total Volume Table" and is Dynamic.
Just Fine in Model Space... yet is showing within a Viewport (typ. plan sheet) that each
Split is simply Staked ontop of each other ?
Thought I (we) came across this a few years ago... yet no issues latetly till now, and also
mainly first time I've likely split the Table in R2012 (currently used).
Have maintaining View Orientation "true", yet still nothing.....
Any thoughts appreicated... just ? and didn't see any other relative post.
Geoff T.
Geoff T.
Xi Computer CM-MasterCase Pro 5 tower case (Win10 O.S.)
Ten Core i9-7900X @ 3.3/4.5GHz Sealed Water Cooled
w/ Asus PRIME X299-A mobo
32GB DDR4 @ 3600Mhz RAM
SSD Samsung 850 EVO H.D.
Nvidia Quadro P2000 (span2) + 2000
3 ViewSonic VG2436wm-LED displays
4 REPLIES 4
wfberry
in reply to: Terrain_IaPLS
Am assuming you meant stacked.
Make your model space scale the same as viewport scale.
Bill
Terrain_IaPLS
in reply to: wfberry
Bill,
Sorry... yes I mean Stacked !
Survey projects on the brain.... and + a Friday.... excuse typo.
Anyhow.... obviously don't want to change M.S. as all my styles / objects in other
V.P.'s would go wild.. So swapped your remarks and made
VP scale = MS Scale (project settings), and POOF.
NOW I remember.... something so siimple for such a stupid overthought.
Missed that basic thought, so appreciate !!
Take Care,
Geoff
Geoff T.
wfberry
Glad it worked out.  Just for the record, changing your MS scale should have no bearing on those styles in other viewports.
Bill
Terrain_IaPLS
Bill,
Correct... V.P. display is product of Civil Object component style(s)
in M.S. and adjusts (scales) respective to V.P. scale desired / defined.
(see how bad of a day this is !!)
Obviously I "meant" how eveything would display in Model Space.....
I QUIT.
Again, appreciate reply's.
Geoff T.
Geoff T.
Rail Community
