Civil 3D Forum
Volume Report Title
3 REPLIES 3
earlesinc
464 Views, 3 Replies
Volume Report Title
Is there any way of adding a street name or project name to the main title on the "Cut & Fill Volume Reports".
I have nine streets. Would be nice to add a street name to the report instead of using the stationing to determine which street I am looking at. Especially since they plot so small in the drawing file. We also position these same reports onto the cross sections sheets, before they are plotted.
Dave
3 REPLIES 3
BrianHailey
in reply to: earlesinc
Only way I know of to do it is different table styles with the information manually entered into the table title. I suppose you could leave the title blank and put in a label that references the alingments name and manualy line it up with the table. This way, if the name of the alignment changes, the label will update and will make it look like the table has updated.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
tcorey
Hi Dave,
I think you mean Cut and Fill Volume "Table," not "Report," right? If so, yes, Civil 3D does this.
When editing the Table Style, in the Structure box, double click the heading where it says Total Volume Table. Parent Alignment Name is one of the properties you can move into the box to replace the static text.
Best regards,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
earlesinc
in reply to: tcorey
Thank you, that worksSmiley HappySmiley Happy
Rail Community
